The DICOTA laptop lock base plate is a vital system accessory for enhancing the security of laptops. Constructed from high-quality zinc alloy, it provides a sturdy and reliable solution to protect your devices from theft or unauthorized access. This product comes with 2 mounting screws and 3M double-sided foam tape, making the installation process simple and efficient. Whether for personal use or in a professional setting, this laptop lock base plate is an essential tool for anyone looking to safeguard their technology.
Enhanced security
The laptop lock base plate made from zinc alloy offers a robust solution for securing laptops. This durable material ensures that the device remains safe and protected against theft or unauthorized use -
Easy installation
With included 2 mounting screws and 3M double-sided foam tape, the installation process is straightforward and hassle-free. This allows for a quick and secure setup on various surfaces without the need for professional assistance
- DICOTA - laptop lock base plate
- Product Type
- Laptop lock base plate
- Package Content
- 2 mounting screws, 3M double sided foam tape
- Silver
- Product Material
- Zinc alloy
- 5.16 cm x 4.7 cm x 2.33 cm
- 50 g
- 2-year warranty
- Product Type
- Product Material
- Zinc alloy
- Package Content
- 5.16 cm
- 4.7 cm
- 2.33 cm
- 50 g
- Silver
- Limited warranty: - 2 years
Dicota Laptop Lock Base Plate
