Our actions of today shape the world of tomorrow. That's why DICOTA relies on ecologically sensible solutions and manufactures all ECO collections from sustainable recycled PET. Up to 31 PET bottles are put to second use. You get an environmentally friendly product, with a lifetime warranty. You don't have to do without the well-known quality, feel and look of the rPET products.
The Eco Tote Bag MOTION optimally protects your laptop with the size 13-15.6" thanks to the notebook compartment padded with High-Density Foam (HDF). The tablet pocket provides reliable protection for devices up to 12.9". Transforms the bag from a briefcase to a backpack in no time at all using stowable backpack straps and a detachable, padded shoulder strap. The spacious main compartment is divided in such a way that documents and accessories can be stowed separately. For even more storage space, the main compartment can be expanded thanks to a zipper. The front pocket with practical pockets creates order in your mobile accessories such as smartphones, pens or chargers. The bag is made of water-repellent material to protect the contents even on rainy days. This makes the Eco Tote Bag MOTION the perfect bag for those who travel a lot and want to support the sensible reuse of PET bottles with an environmentally friendly carrying solution.
- Made from 12 recycled PET bottles
- Padded notebook compartment with High-Density Foam (HDF)
- Pocket for tablets up to 12.9"
- Spacious main compartment with subdivision for documents and accessories
- Front pocket with storage space for mobile accessories
- Zipper to expand storage space
- Comfortable, stowable shoulder straps for backpack function
- Water-repellent material
- DICOTA Motion Eco - notebook carrying backpack/tote
- Product Type
- Notebook carrying backpack/tote
- Black
- Product Material
- Recycled PET polyester
- 32.5 cm x 6.5 cm x 42 cm
- 770 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 13" - 15.6" / 33 cm - 39.6 cm
- Water repellent
- Carrying Strap
- Removable/adjustable padded shoulder straps
- Limited lifetime warranty
- Product Type
- Product Material
- 32.5 cm
- 6.5 cm
- 42 cm
- 770 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3 cm
- Expandable
- Additional Compartments
- Tablet, front pocket
- Water repellent
- Carrying Strap
- Closure Type
- Zipper
- Black
- Limited warranty: - lifetime
