Dicota Eco Top Traveller Twin SELECT 14-15.6"
Quicklinx: FC38WS00 Mfr#: D31646
£74.67 ex VAT
£89.60 inc VAT
Made from high-quality recycled PET, the SELECT collection cares for the planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Top Traveler Twin SELECT's main material is made of 10 recycled PET bottles. The light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. There's also space for a tablet and accessories in this spacious and versatile bag, which offers clever storage solutions.
The lockable notebook compartment provides the perfect protection for your 14 - 15.6" device with surrounding high-density foam (HDF) padding and perforated, lightweight EVA foam corner padding. The elastic fastening strap makes your device even more secure. The expandable main compartment has plenty of space for documents and other mobile devices such as printers. Your tablet (up to 10.5") can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional front pocket provides space for chargers and cables. Documents can be stored in the zip compartment on the back of the bag or in the slot for quick access. A length-adjustable and padded shoulder strap, the trolley fastening strap on the back and intelligent inner cable routing ensure perfect comfort when traveling.
DICOTA Top Traveller ECO Twin SELECT - notebook carrying case
Notebook carrying case
Product Material
Recycled PET
43 cm x 18.5 cm x 32 cm
1 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
High-Density Foam (HDF), EVA frame protection, padded slip pocket, shock absorption, lockable notebook compartment, up 10.5" tablet support, expandable main compartment
Carrying Strap
Trolley strap, removable shoulder strap, top carrying handles
Product Material
Recycled PET
43 cm
18.5 cm
32 cm
1 kg
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Mobile phone, documents, mobile accessories, tablet, front external zipped pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
Brand: Dicota
