Dicota Eco Top Traveller Twin PRO 14-15.6"
Quicklinx: GQLFWS00 Mfr#: D30844-RPET
Our actions of today shape the world of tomorrow. That's why DICOTA relies on ecologically sensible solutions and manufactures all ECO collections from sustainable recycled PET. Up to 45 PET bottles are put to second use. You get an environmentally friendly product, with a lifetime warranty. You don't have to do without the well-known quality, feel and look of the rPET products.
With Eco Top Traveller Twin PRO you drive "1st class". The expandable toploader bag reliably accompanies you everywhere and meets the highest standards of quality, functionality and protection. The fitall system partition in the notebook compartment rests protectively over your notebook and automatically adapts to the sizes of 14-15.6". The perforated and therefore lightweight EVA foam in the lockable notebook compartment protects the edges of the device first-class. The anti-slip technology coating guarantees optimal grip for your notebook in the compartment and the length-adjustable, padded shoulder strap. Best protection for your tablet up to 12.9" by the EVA-shaped compartment with extra soft Nylex inner lining. Front pocket with key fob, storage space for mobile accessories and pockets for personal utensils. Zipper compartment for ID cards. The bag is light and comfortable in your hand, thanks to high-quality carrying handles made of genuine leather. Trolley strap can be used as an additional document compartment. Pocket bottom made of waterproof material. DICOTTA's attention to detail makes this bag your most reliable business partner! This makes the Eco Top Traveller Twin PRO perfect for those who travel a lot and want to support the sensible reuse of PET bottles with an environmentally friendly carrying solution.
  • Made from 29 recycled PET bottles
  • Maximum protection thanks to memory foam and EVA frame protection
  • EVA-shaped compartment with Nylex inner lining for tablets up to 12.9"
  • Expandable compartment for documents and mobile accessories
  • Two document trays on the back
  • Large front pocket with zipper compartment, key fob and pockets for mobile accessories
  • Additional front pocket for power supply and cable
  • Length-adjustable, padded shoulder strap with anti-slip technology
  • Trolley strap can be used as an additional document compartment
  • Comfortable carrying handles made of genuine leather
  • Pocket bottom made of waterproof material
  • Address tag included
DICOTA Eco Top Traveller Twin PRO - notebook carrying backpack
Notebook carrying backpack
Product Material
1680D rPET polyester
41 cm x 20.5 cm x 31 cm
1.61 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Anti-Slip System, waterproof bottom, fitall system, lockable notebook compartment, padded notebook compartment, 12.9" tablet support
Carrying Strap
Top carrying handles, adjustable padded shoulder strap, luggage strap
Product Material
41 cm
20.5 cm
31 cm
1.61 kg
15.6"
Notebook Compatibility Dimensions
38 cm x 26.5 cm x 4 cm
Additional Compartments
Front pocket, internal slip pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
