Dicota Eco Top Traveller SELECT 14-15.6"
Quicklinx: GWZ8QE00 Mfr#: D31644-RPET
£58.19 ex VAT
£69.82 inc VAT
Today's actions shape tomorrow's world. Which is why, here at DICOTA, we are dedicated to developing environmentally friendly solutions and therefore make all the items in our ECO collections out of sustainable, recycled PET. We reuse up to 36 PET bottles, so you will receive an environmentally friendly product with a life-long guarantee. Our PET products also have the quality, look and finish that you know and love.
Made from high-quality recycled PET, without compromising on quality, functionality or design. The light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. There's also space for a tablet and accessories in this spacious and versatile bag, which offers clever storage solutions. The lockable notebook compartment provides the perfect protection for your 14-15.6" device with surrounding high-density foam (HDF) padding and perforated, lightweight EVA foam corner padding. The elastic fastening strap makes your device even more secured. The roomy main compartment offers plenty of space for papers or anything else you need to carry. Your tablet up to 12.9" can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organised with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional front pocket provides space for chargers and cables. Documents can be stored in the separate slot on the back of the bag. A length-adjustable and padded shoulder strap, the trolley fastening strap on the back and intelligent inner cable routing ensure perfect comfort when travelling. The Top Traveller Eco SELECT is perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
  • Made of 8 recycled PET bottles
  • Adjustable shoulder strap with comfortable padding
  • Lockable notebook compartment, surrounded by High-Density Foam (HDF) and including EVA Corner Foam Protection as protective padding
  • Smart inner cable management for mobile charging of your devices
  • Spacious main compartment with storage area for documents
  • Padded slip pocket for tablets
  • Front compartment with workstation for mobile accessories
  • Additional zip pocket for power supply unit and cable
  • Trolley fastening strap
DICOTA Eco Top Traveller SELECT - notebook carrying case
Notebook carrying case
Product Material
300D recycled PET
42.5 cm x 13 cm x 31 cm
790 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
High-Density Foam (HDF), EVA frame protection, lockable notebook compartment, fastening system, padded tablet compartment, 12.9" tablet support
Carrying Strap
Top carrying handles, adjustable padded shoulder strap, luggage strap
Product Material
300D recycled PET
42.5 cm
13 cm
31 cm
790 g
15.6"
Additional Compartments
Back pocket, front pocket, internal slip pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
Brand: Dicota
