Made from high-quality recycled PET, the SELECT collection cares for the planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Top Traveler SELECT's main material is made of 8 recycled PET bottles. The light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. There's also space for a tablet and accessories in this spacious and versatile bag, which offers clever storage solutions.
The lockable notebook compartment provides the perfect protection for your 14 - 15.6" device with surrounding high-density foam (HDF) padding and perforated, lightweight EVA foam corner padding. The elastic fastening strap makes your device even more secure. The roomy main compartment offers plenty of space for papers or anything else you need to carry. Your tablet (up to 10.5") can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional front pocket provides space for chargers and cables. Documents can be stored in the separate slot on the back of the bag. A length-adjustable and padded shoulder strap, the trolley fastening strap on the back and intelligent inner cable routing ensure perfect comfort when traveling.
- DICOTA Top Traveller ECO SELECT - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Recycled PET
- 42.5 cm x 13 cm x 31 cm
- 800 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 14" - 15.6" / 35.6 cm - 39.6 cm
- High-Density Foam (HDF), EVA frame protection, padded slip pocket, shock absorption, lockable notebook compartment, up 10.5" tablet support
- Carrying Strap
- Trolley strap, removable shoulder strap, top carrying handles
- Limited lifetime warranty
- Product Type
- Product Material
- Recycled PET
- 42.5 cm
- 13 cm
- 31 cm
- 800 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3.5 cm
- Additional Compartments
- Mobile phone, documents, mobile accessories, tablet, front external zipped pocket
- Carrying Strap
- Closure Type
- Zipper
- Black
- Limited warranty: - lifetime
