Dicota Eco Top Traveller PRO 12-14.1"
Quicklinx: GFPPWS00 Mfr#: D30842-RPET
£95.41 ex VAT
£114.49 inc VAT
At DICOTA, they are dedicated to developing environmentally friendly solutions and therefore make all the items in the Eco collections out of sustainable, recycled PET. They reuse PET bottles, so you will receive an environmentally friendly product. The PET products also have the quality, look and finish that you know and love.
Travel 1st class with the Eco Top Traveller PRO. The top loader bag reliably accompanies you everywhere and meets the highest standards of quality, functionality and protection: DICOTA's attention to detail makes this bag one of your most reliable business partners! The fit-all system separating wall in the notebook compartment lies protectively across your notebook and fits automatically to sizes from 15-17.3". The perforated and thus light EVA foam material in the lockable notebook compartment perfectly protects the edges of your device. The anti-slip technology coating ensures perfect grip for your notebook in the compartment. Excellent protection for your tablet up to 12.9" thanks to the EVA-shaped compartment with extra-soft Nylex inner lining. Generous storage space for documents. The front pocket with keychain and insert pockets allows you to organize the personal equipment and provides space for additional mobile accessories. Additional pocket for charger and cables. The bag is light and comfortable in your hand thanks to the high-quality genuine leather handles. The trolley strap can also be used as an additional document compartment. The bag bottom is made of waterproof material. The Eco Top Traveller PRO is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco Top Traveller PRO - notebook carrying backpack
Notebook carrying backpack
Product Material
1680D rPET polyester
40 cm x 15 cm x 30 cm
1.36 kg
Notebook Compatibility
14.1"
Notebook Supported Sizes
12" - 14.1" / 30.5 cm - 43.9 cm
Waterproof, Anti-Slip System, slip pocket, zippered front pocket, fitall system, EVA frame protection, lockable notebook compartment, 12.9" tablet support
Carrying Strap
Adjustable shoulder strap, carrying handle
Product Material
40 cm
15 cm
30 cm
1.36 kg
14.1"
Notebook Compatibility Dimensions
34 cm x 24.5 cm x 4 cm
Additional Compartments
Power adapter, front pocket, document compartment
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
Brand: Dicota
