Dicota Eco Top Traveller Dual SELECT 14-15.6"
Quicklinx: FC35WS00 Mfr#: D31645
£60.92 ex VAT
£73.10 inc VAT
Eco Top Traveller Dual SELECT is the intelligent top loader/backpack combination for environmentally conscious professionals. You can decide on the go if you'd rather have a shoulder bag or a backpack. If you want to wear the Top Traveller ECO Dual over your shoulder, you will love the stowable comfortable carry handle and removable padded shoulder strap. In the backpack version, the bag has stowable padded shoulder straps that can be adjusted in length. The Eco Top Traveller Dual SELECT's main material is made of 12 recycled PET bottles. The EVA foam padding perfectly fits the contours of your device, which can also be fixed with an elastic strap.
Your 14 - 15.6" notebook is triple-protected: with high-density foam (HDF) padding, perforated, lightweight EVA foam corner padding and an elastic strap. The padded compartment for tablets (up to 10.5") protects against impact and is also equipped with Nylex inside. Generous storage space (expandable) for your documents and other luggage in the spacious and lockable main compartment. The practical and easy-access insert pockets in the front pocket allow you to organize your personal equipment such as IDs, business cards, smartphones and portable chargers. An additional front pocket provides space for chargers and cables. The length-adjustable padded shoulder strap, the trolley fastening strap and the intelligent inner cable routing ensure perfect comfort when out and about.
DICOTA Top Traveller ECO Dual SELECT - notebook carrying case
Notebook carrying case
Product Material
Recycled PET
43 cm x 31 cm x 14 cm
1.1 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
High-Density Foam (HDF), reinforced frame, transformable into a backpack, retractable shoulder straps, nylex inner lining, EVA padding, padded tablet compartment, 2-way combo case
Carrying Strap
Trolley strap, top carry handle, adjustable padded shoulder strap
Product Material
Recycled PET
43 cm
31 cm
14 cm
1.1 kg
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Tablet, front pocket, accessory pocket
Carrying Strap
Closure Type
Double zipper
Brand: Dicota
