The compact Eco Traveller BASE case offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design. There is an extra compartment in which you can easily store documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
The case is comfortable to carry thanks to its Neoprene padded carrying handle and it can be attached to a suitcase in seconds with its built-in strap. You can also carry the case using its adjustable shoulder strap. The Eco Traveller BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
- DICOTA Eco Top Traveller BASE - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 300D RPET polyester
- 44 cm x 10 cm x 32.5 cm
- 850 g
- Notebook Compatibility
- 17.3"
- Notebook Supported Sizes
- 15" - 17.3" / 38.1 cm - 43.9 cm
- Padded handles, removable shoulder strap, adjustable shoulder strap, High-Density Foam (HDF), metal frame, padded notebook compartment
- Carrying Strap
- Shoulder carrying strap, trolley strap, top carrying handles
- 30 years warranty
- Product Type
- Product Material
- 44 cm
- 10 cm
- 32.5 cm
- 850 g
- 17.3"
- Notebook Compatibility Dimensions
- 42 cm x 30 cm x 4.5 cm
- Additional Compartments
- Documents, mobile accessories, front zippered pocket
- Carrying Strap
- Closure Type
- Zipper
- Black
- Limited warranty: - 30 years
