Dicota Eco Top Traveller BASE 15-17.3
Quicklinx: GDVXWS00 Mfr#: D31671-RPET
49 In Stock
£29.79 ex VAT
£35.74 inc VAT
The compact Eco Traveller BASE case offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design. There is an extra compartment in which you can easily store documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
The case is comfortable to carry thanks to its Neoprene padded carrying handle and it can be attached to a suitcase in seconds with its built-in strap. You can also carry the case using its adjustable shoulder strap. The Eco Traveller BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco Top Traveller BASE - notebook carrying case
Notebook carrying case
Product Material
300D RPET polyester
44 cm x 10 cm x 32.5 cm
850 g
Notebook Compatibility
17.3"
Notebook Supported Sizes
15" - 17.3" / 38.1 cm - 43.9 cm
Padded handles, removable shoulder strap, adjustable shoulder strap, High-Density Foam (HDF), metal frame, padded notebook compartment
Carrying Strap
Shoulder carrying strap, trolley strap, top carrying handles
30 years warranty
Product Material
300D RPET polyester
44 cm
10 cm
32.5 cm
850 g
17.3"
Notebook Compatibility Dimensions
42 cm x 30 cm x 4.5 cm
Additional Compartments
Documents, mobile accessories, front zippered pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - 30 years
Brand: Dicota
