The compact Eco Traveler BASE case offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design.
There is an extra compartment in which you can easily store documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand. The case is comfortable to carry thanks to its neoprene padded carrying handle and it can be attached to a suitcase in seconds with its built-in strap.
You can also carry the case using its adjustable shoulder strap. The Eco Traveler BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
- DICOTA Eco - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 300D RPET polyester
- 40.5 cm x 8.5 cm x 30.5 cm
- 800 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 15" - 16" / 38.1 cm - 40.6 cm
- High-Density Foam (HDF), padded notebook compartment, elastic fixation straps
- Carrying Strap
- Grab handle, chest strap, adjustable shoulder strap
- 30 years warranty
- Product Type
- Product Material
- 40.5 cm
- 8.5 cm
- 30.5 cm
- 800 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 4 cm
- Additional Compartments
- Documents, mobile accessories, mobile phone, front zippered pocket, power bank, pens
- Carrying Strap
- Closure Type
- Zipper
- Black
- REACH
- Limited warranty: - 30 years
Dicota Eco Top Traveller BASE 15-15.6"
