Dicota Eco Top Traveller BASE 13-14.1"
Quicklinx: G91QWS00 Mfr#: D31324-RPET
More than 50 In Stock
£23.16 ex VAT
£27.79 inc VAT
The compact Eco Traveller BASE case offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design. There is an extra compartment in which you can easily store documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
The case is comfortable to carry thanks to its Neoprene padded carrying handle and it can be attached to a suitcase in seconds with its built-in strap. You can also carry the case using its adjustable shoulder strap. The Eco Traveller BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco Top Traveller BASE - notebook carrying case
Notebook carrying case
Product Material
Metal, neoprene, 300D RPET polyester
38 cm x 8 cm x 28 cm
750 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
13" - 14.1" / 33 cm - 35.8 cm
High-Density Foam (HDF), metal frame, adjustable laptop security belt, padded notebook compartment
Carrying Strap
Trolley strap, removable/adjustable shoulder strap, padded carry handles
30 years warranty
Product Material
38 cm
8 cm
28 cm
750 g
14.1"
Notebook Compatibility Dimensions
35 cm x 24.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, documents, mobile accessories, chargers, front zippered pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - 30 years
Brand: Dicota
