The Eco Slim Case Plus BASE offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case fully protects your device and the elastic strap also secures it within its compartment. The case is comfortable to carry thanks to its padded carrying handle and adjustable shoulder strap. There is an extra compartment on the back, in which you can easily store documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
There is also a separate compartment for your power bank and cables, so you can keep them organized. The Eco Slim Case Plus BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
- DICOTA Eco - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 300D RPET polyester
- 40.5 cm x 4 cm x 29.5 cm
- 400 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 13" - 15.6" / 33 cm - 39.6 cm
- High-Density Foam (HDF), elastic fixation straps, padded notebook compartment
- Carrying Strap
- Trolley strap, removable/adjustable shoulder strap, padded carry handles
- 30 years warranty
- Product Type
- Product Material
- 40.5 cm
- 4 cm
- 29.5 cm
- 400 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3 cm
- Additional Compartments
- Cable, documents, mobile accessories, power bank, front zippered pocket
- Carrying Strap
- Closure Type
- Zipper
- Black
- Limited warranty: - 30 years
