Dicota Eco Slim Case Plus BASE 13-15.6"
Quicklinx: G91ZWS00 Mfr#: D31838-RPET
36 In Stock
£21.64 ex VAT
£25.96 inc VAT
The Eco Slim Case Plus BASE offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case fully protects your device and the elastic strap also secures it within its compartment. The case is comfortable to carry thanks to its padded carrying handle and adjustable shoulder strap. There is an extra compartment on the back, in which you can easily store documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
There is also a separate compartment for your power bank and cables, so you can keep them organized. The Eco Slim Case Plus BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
DICOTA Eco - notebook carrying case
Notebook carrying case
Product Material
300D RPET polyester
40.5 cm x 4 cm x 29.5 cm
400 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" / 33 cm - 39.6 cm
High-Density Foam (HDF), elastic fixation straps, padded notebook compartment
Carrying Strap
Trolley strap, removable/adjustable shoulder strap, padded carry handles
30 years warranty
Product Material
300D RPET polyester
40.5 cm
4 cm
29.5 cm
400 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3 cm
Additional Compartments
Cable, documents, mobile accessories, power bank, front zippered pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - 30 years
Brand: Dicota
