Our actions of today shape the world of tomorrow. That's why DICOTA relies on ecologically sensible solutions and manufactures all ECO collections from sustainable recycled PET. Up to 31 PET bottles are put to second use. You get an environmentally friendly product, with a lifetime warranty. You don't have to do without the well-known quality, feel and look of the rPET products.
The Eco Slim Case MOTION is the lightweight and slim carrying solution for your laptop. In the notebook compartment padded with high density foam, devices from 10-11.6" are optimally protected. The pocket for tablets provides reliable protection for devices up to 10.9". Carry your bag comfortably with the padded handle or use the length-adjustable shoulder strap. On the back there is a useful document compartment in which documents can be easily stowed away. In the practical front compartment you will find enough space for the smartphone or other mobile accessories such as cables, pens or chargers, which should always be at hand. The bag is made of water-repellent material to protect the contents even on rainy days. This makes the Eco Slim Case MOTION the perfect bag for those who travel a lot and want to support the sensible reuse of PET bottles with an environmentally friendly carrying solution.
- Made from 4.5 recycled PET bottles
- Padded notebook compartment with High-Density Foam (HDF)
- Pocket for tablets up to 10.9"
- Front pocket with storage space for mobile accessories
- Document compartment on the back of the bag
- Padded carrying handles
- Detachable, length-adjustable shoulder strap
- Water-repellent material
- DICOTA Eco Motion - notebook carrying case
- Product Type
- Notebook carrying case
- Light grey
- Product Material
- Recycled PET polyester
- 33 cm x 4.2 cm x 23 cm
- 450 g
- Notebook Compatibility
- 11.6"
- Notebook Supported Sizes
- 10" - 11.6" / 25.4 cm - 29.5 cm
- High-Density Foam (HDF), water repellent, padded notebook compartment
- Carrying Strap
- Padded top handles, removable/adjustable shoulder strap
- 30 years warranty
- Product Type
- Product Material
- 33 cm
- 4.2 cm
- 23 cm
- 450 g
- 11.6"
- Notebook Compatibility Dimensions
- 30 cm x 20.5 cm x 3 cm
- Additional Compartments
- Mobile accessories, front pocket, internal slip pocket, document compartment
- Carrying Strap
- Closure Type
- Zipper
- Light grey
- Limited warranty: - 30 years
