Dicota Eco Slim Case BASE 13-14.1"
Quicklinx: G91DWS00 Mfr#: D31304-RPET
12 In Stock
£15.98 ex VAT
£19.17 inc VAT
The Eco Slim Case BASE is a light, slim laptop case. Devices are well protected in the padded notebook compartment. The case is comfortable to carry thanks to its padded carrying handle and adjustable shoulder strap. The extra compartment on the back is especially handy for easily storing documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand. The Eco Slim Case BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco Slim Case BASE - notebook carrying case
Notebook carrying case
Product Material
Metal, 300D RPET polyester
37 cm x 3.5 cm x 27.5 cm
350 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
13" - 14.1" / 33 cm - 35.8 cm
Metal frame, adjustable laptop security belt, padded notebook compartment
Carrying Strap
Removable/adjustable shoulder strap, padded carry handles
30 years warranty
Product Material
37 cm
3.5 cm
27.5 cm
350 g
14.1"
Notebook Compatibility Dimensions
35 cm x 24.5 cm x 3 cm
Additional Compartments
Cable, documents, pens, mobile accessories, chargers, front zippered pocket
Carrying Strap
Closure Type
Zipper
REACH
Limited warranty: - 30 years
Brand: Dicota
