The Eco Slim Case BASE is a light, slim laptop case. Devices are well protected in the padded notebook compartment. The case is comfortable to carry thanks to its padded carrying handle and adjustable shoulder strap. The extra compartment on the back is especially handy for easily storing documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand. The Eco Slim Case BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
- DICOTA Eco Slim Case BASE - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Metal, 300D RPET polyester
- 37 cm x 3.5 cm x 27.5 cm
- 350 g
- Notebook Compatibility
- 14.1"
- Notebook Supported Sizes
- 13" - 14.1" / 33 cm - 35.8 cm
- Metal frame, adjustable laptop security belt, padded notebook compartment
- Carrying Strap
- Removable/adjustable shoulder strap, padded carry handles
- 30 years warranty
- Product Type
- Product Material
- 37 cm
- 3.5 cm
- 27.5 cm
- 350 g
- 14.1"
- Notebook Compatibility Dimensions
- 35 cm x 24.5 cm x 3 cm
- Additional Compartments
- Cable, documents, pens, mobile accessories, chargers, front zippered pocket
- Carrying Strap
- Closure Type
- Zipper
- Black
- REACH
- Limited warranty: - 30 years
