Dicota Eco Slim Case BASE 11-12.5" Grey
Quicklinx: G91CWS00 Mfr#: D31301-RPET
£13.67 ex VAT
£16.40 inc VAT
The Eco Slim Case BASE is a light, slim laptop case. Devices are well protected in the padded notebook compartment. The case is comfortable to carry thanks to its padded carrying handle and adjustable shoulder strap. The extra compartment on the back is especially handy for easily storing documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand. The Eco Slim Case BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco Slim Case BASE - notebook carrying case
Notebook carrying case
Grey
Product Material
Metal, 300D RPET polyester
33.5 cm x 3.5 cm x 22.5 cm
320 g
Notebook Compatibility
12.5"
Notebook Supported Sizes
11" - 12.5" / 27.9 cm - 31.8 cm
Metal frame, adjustable laptop security belt, padded notebook compartment
Carrying Strap
Removable/adjustable shoulder strap, padded carry handles
30 years warranty
Product Material
33.5 cm
3.5 cm
22.5 cm
320 g
12.5"
Notebook Compatibility Dimensions
31.5 cm x 21.5 cm x 3 cm
Additional Compartments
Mobile phone, cable, documents, pens, mobile accessories, chargers, front zippered pocket
Carrying Strap
Closure Type
Zipper
Grey
REACH
Limited warranty: - 30 years
Brand: Dicota
