Dicota Eco Multi Twin SELECT 14-15.6"
Quicklinx: GWZ7WS00 Mfr#: D31641-RPET
Hurry, only 2 left in stock!
£66.92 ex VAT
£80.30 inc VAT
Made from high-quality recycled PET, the SELECT collection cares for planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Multi Twin SELECT's main material is made of 9 recycled PET bottles. The light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. There's also space for a tablet and accessories in this spacious and versatile bag, which offers clever storage solutions.
The notebook compartment perfectly protects your 14 - 15.6" device with padding made of high-density foam (HDF) and soft Nylex material as well as an elastic fastening strap. Your tablet (up to 10.5") can also be safely stored in the padded compartment. The lockable main compartment has plenty of space for printers and projectors. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional front pocket provides space for power supplies and cables. Documents can be stored in the zip pocket on the back or in the slot for quick access. Adjustable and padded shoulder straps, a trolley fastening strap on the back and intelligent inner cable routing ensure perfect comfort when traveling.
DICOTA Multi Twin ECO SELECT - notebook carrying case
Notebook carrying case
Product Material
Recycled PET
42 cm x 30 cm x 20 cm
1.3 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
High-Density Foam (HDF), EVA frame protection, padded tablet compartment
Carrying Strap
Trolley strap, top carry handle, adjustable padded shoulder strap
Product Material
Recycled PET
42 cm
30 cm
20 cm
1.3 kg
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Printer, projector, tablet, folder, front pocket, external zippered pocket, accessory pocket
Carrying Strap
Closure Type
Double zipper
Brand: Dicota
