Made from high-quality recycled PET, the SELECT collection cares for planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Multi Twin SELECT's main material is made of 9 recycled PET bottles. The light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. There's also space for a tablet and accessories in this spacious and versatile bag, which offers clever storage solutions.
The notebook compartment perfectly protects your 14 - 15.6" device with padding made of high-density foam (HDF) and soft Nylex material as well as an elastic fastening strap. Your tablet (up to 10.5") can also be safely stored in the padded compartment. The lockable main compartment has plenty of space for printers and projectors. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional front pocket provides space for power supplies and cables. Documents can be stored in the zip pocket on the back or in the slot for quick access. Adjustable and padded shoulder straps, a trolley fastening strap on the back and intelligent inner cable routing ensure perfect comfort when traveling.
 - DICOTA Multi Twin ECO SELECT - notebook carrying case
- Product Type
 - Notebook carrying case
 - Black
- Product Material
 - Recycled PET
 - 42 cm x 30 cm x 20 cm
 - 1.3 kg
- Notebook Compatibility
 - 15.6"
- Notebook Supported Sizes
 - 14" - 15.6" / 35.6 cm - 39.6 cm
 - High-Density Foam (HDF), EVA frame protection, padded tablet compartment
- Carrying Strap
 - Trolley strap, top carry handle, adjustable padded shoulder strap
- Product Type
- Product Material
 - Recycled PET
 - 42 cm
 - 30 cm
 - 20 cm
 - 1.3 kg
 - 15.6"
- Notebook Compatibility Dimensions
 - 38.5 cm x 26.5 cm x 3.5 cm
- Additional Compartments
 - Printer, projector, tablet, folder, front pocket, external zippered pocket, accessory pocket
- Carrying Strap
- Closure Type
 - Double zipper
 - Black
