Dicota Eco Multi SELECT 15-17.3"
Quicklinx: GWZ6WS00 Mfr#: D31639-RPET
Today's actions shape tomorrow's world. Which is why, here at DICOTA, we are dedicated to developing environmentally friendly solutions and therefore make all the items in our ECO collections out of sustainable, recycled PET. We reuse up to 36 PET bottles, so you will receive an environmentally friendly product with a life-long guarantee. Our PET products also have the quality, look and finish that you know and love.
Ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The bag offers perfect protection for your devices and is comfortable and easy to carry. There's also space for a tablet and accessories in this spacious bag, which offers clever storage solutions. The lockable, clamshell-style main compartment keeps your 15-17.3" notebook protected with surrounding high-density foam (HDF) padding and soft Nylex, a metal-reinforced frame, and reliable fastening thanks to the fastening strap. Your tablet up to 12.9" can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organised with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional zip compartment on the lower front of the bag provides space for a charger and cable. The comfortably moulded riveted carrying handle, a length-adjustable and padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport. The Eco Multi Plus SELECT is perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
  • Made of 8 recycled PET bottles
  • Comfortable carry handles
  • Adjustable shoulder strap with padding
  • Lockable notebook compartment with a metal-reinforced frame
  • Slip pocket for tablets measuring up to 12.9"
  • Front compartment with workstation for mobile accessories
  • Smart inner cable management for mobile charging of your devices
  • Surrounding High-Density Foam (HDF) and soft nylex material as protective padding
  • Document compartment on the back
  • Suitcase fixation strap
DICOTA Eco Multi SELECT - notebook carrying case
Notebook carrying case
Product Material
Metal, high-density foam, 300D recycled PET
46 cm x 11 cm x 33 cm
990 g
Notebook Compatibility
17.3"
Notebook Supported Sizes
15" - 17.3" / 39.6 cm - 43.9 cm
Metal frame, padded notebook compartment, fixation strap
Carrying Strap
Trolley strap, top carry handle, removable/adjustable padded shoulder strap
30 years warranty
Product Material
46 cm
11 cm
33 cm
990 g
17.3"
Notebook Compatibility Dimensions
42 cm x 29.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, documents, mobile accessories, front zippered pocket, 12.9" tablet
Carrying Strap
Closure Type
Zipper, zipper pocket
Lining Material
Soft nylex
Limited warranty: - 30 years
