Made from high-quality recycled PET, the SELECT collection cares for our planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Multi SELECT's main material is made of 7 recycled PET bottles. The bag offers perfect protection for your devices and is comfortable and easy to carry. There's also space for a tablet and accessories in this spacious bag, which offers clever storage solutions.
The lockable, clamshell-style main compartment keeps your 14 - 15.6" notebook protected with surrounding high-density foam (HDF) padding and soft Nylex, a metal-reinforced frame, and reliable fastening thanks to the fastening strap. Your tablet (up to 10.5") can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional zip compartment on the lower front of the bag provides space for a charger and cable. The comfortably molded riveted carrying handle, a length-adjustable and padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport.
- DICOTA Eco Multi SELECT - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Recycled PET
- 42 cm x 30 cm x 10 cm
- 1 kg
- Notebook Compatibility
- 15.6"
- High-Density Foam (HDF), reinforced frame, padded tablet compartment
- Carrying Strap
- Top carry handle, adjustable padded shoulder strap
- Product Type
- Product Material
- Recycled PET
- 42 cm
- 30 cm
- 10 cm
- 1 kg
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3.5 cm
- Additional Compartments
- Tablet, accessory pocket
- Carrying Strap
- Closure Type
- Double zipper
- Black
Dicota Eco Multi SELECT 14-15.6"
