Dicota Eco Multi SELECT 14-15.6"
Quicklinx: FC31WS00 Mfr#: D31638
£37.16 ex VAT
£44.59 inc VAT
Made from high-quality recycled PET, the SELECT collection cares for our planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Multi SELECT's main material is made of 7 recycled PET bottles. The bag offers perfect protection for your devices and is comfortable and easy to carry. There's also space for a tablet and accessories in this spacious bag, which offers clever storage solutions.
The lockable, clamshell-style main compartment keeps your 14 - 15.6" notebook protected with surrounding high-density foam (HDF) padding and soft Nylex, a metal-reinforced frame, and reliable fastening thanks to the fastening strap. Your tablet (up to 10.5") can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional zip compartment on the lower front of the bag provides space for a charger and cable. The comfortably molded riveted carrying handle, a length-adjustable and padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport.
DICOTA Eco Multi SELECT - notebook carrying case
Notebook carrying case
Product Material
Recycled PET
42 cm x 30 cm x 10 cm
1 kg
Notebook Compatibility
15.6"
High-Density Foam (HDF), reinforced frame, padded tablet compartment
Carrying Strap
Top carry handle, adjustable padded shoulder strap
Product Material
Recycled PET
42 cm
30 cm
10 cm
1 kg
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Tablet, accessory pocket
Carrying Strap
Closure Type
Double zipper
