Dicota Eco Multi SCALE 15-17.3" - Black
Quicklinx: GWYYWS00 Mfr#: D31432-RPET
More than 50 In Stock
£35.28 ex VAT
£42.33 inc VAT
oday's actions shape tomorrow's world. Which is why, here at DICOTA, we are dedicated to developing environmentally friendly solutions and therefore make all the items in our ECO collections out of sustainable, recycled PET. We reuse up to 36 PET bottles, so you will receive an environmentally friendly product with a life-long guarantee. Our PET products also have the quality, look and finish that you know and love.
The Eco Multi SCALE offers excellent protection for your devices and is comfortable and easy to carry. Designed for daily use. Equipped with practical functions that make your life easier. There's triple protection for your 15-17.3" laptop in the lockable main compartment: with surrounding high-density foam padding (HDF), a metal-reinforced frame, and reliable fastening thanks to the fastening strap and an adjustable divider. Even your tablet up to 12.9" can be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organised with its functional division into compartments for a smartphone, portable charger, pens and other mobile accessories. Documents can fit into the separate slot on the back of the bag. The comfortably moulded riveted carrying handles, an adjustable padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport. The Eco Multi SCALE is perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
  • Made of 10 recycled PET bottles
  • Lockable and highly padded laptop compartment
  • Metal frame for extra protection
  • Surrounding High-Density Foam as protective padding
  • Reliable fastening thanks to fastening strap and adjustable divider
  • Slip pocket for tablets measuring up to 12.9"
  • Front pocket with functional compartments for mobile accessories
  • External document compartment on the back of the bag
  • Riveted carrying handle, designed for comfort
  • Adjustable, removable and padded shoulder strap
  • Trolley fastening strap
  • Eco-friendly design
    Crafted from 600D recycled PET, the DICOTA Eco Multi SCALE carrying case combines sustainability with durability, offering an environmentally friendly solution for transporting your notebook and tablet.
  • Enhanced protection
    Equipped with High-Density Foam (HDF) and a lockable notebook compartment, this carrying case ensures your devices are safeguarded against impacts and unauthorized access, providing peace of mind during travel.
  • Versatile storage options
    Featuring additional compartments including a divider, front pocket, and internal slip pocket, the DICOTA Eco Multi SCALE carrying case offers organized storage for all your essentials, alongside 12.9" tablet support for your digital devices.
DICOTA Eco Multi SCALE - notebook carrying case
Notebook carrying case
Product Material
600D recycled PET
44 cm x 6.5 cm x 32.5 cm
940 g
Notebook Compatibility
17.3"
Notebook Supported Sizes
15" - 17.3" / 38.1 cm - 43.9 cm
High-Density Foam (HDF), reinforced frame, lockable notebook compartment, padded notebook compartment, 12.9" tablet support
Carrying Strap
Top carry handle, luggage strap, removable/adjustable padded shoulder strap
Product Material
600D recycled PET
44 cm
6.5 cm
32.5 cm
940 g
17.3"
Notebook Compatibility Dimensions
42 cm x 28.5 cm x 4 cm
Additional Compartments
Front pocket, internal slip pocket, divider
Carrying Strap
Closure Type
Double zipper
Limited warranty: - lifetime
Brand: Dicota
