Dicota Eco Multi SCALE 14-15.6 - Black
Quicklinx: GWYXWS00 Mfr#: D31431-RPET
Hurry, only 1 left in stock!
£28.19 ex VAT
£33.82 inc VAT
Today's actions shape tomorrow's world. Which is why, here at DICOTA, we are dedicated to developing environmentally friendly solutions and therefore make all the items in our ECO collections out of sustainable, recycled PET. We reuse up to 36 PET bottles, so you will receive an environmentally friendly product with a life-long guarantee. Our PET products also have the quality, look and finish that you know and love.
The Eco Multi SCALE offers excellent protection for your devices and is comfortable and easy to carry. Designed for daily use. Equipped with practical functions that make your life easier. There's triple protection for your 14-15.6" laptop in the lockable main compartment: with surrounding high-density foam padding (HDF), a metal-reinforced frame, and reliable fastening thanks to the fastening strap and an adjustable divider. Even your tablet up to 12.9" can be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organised with its functional division into compartments for a smartphone, portable charger, pens and other mobile accessories. Documents can fit into the separate slot on the back of the bag. The comfortably moulded riveted carrying handles, an adjustable padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport. The Eco Multi SCALE is perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
  • Made of 8 recycled PET bottles
  • Lockable and highly padded laptop compartment
  • Metal frame for extra protection
  • Surrounding High-Density Foam as protective padding
  • Reliable fastening thanks to fastening strap and adjustable divider
  • Slip pocket for tablets measuring up to 12.9"
  • Front pocket with functional compartments for mobile accessories
  • External document compartment on the back of the bag
  • Riveted carrying handle, designed for comfort
  • Adjustable, removable and padded shoulder strap
  • Trolley fastening strap
DICOTA Multi SCALE - notebook carrying case
Notebook carrying case
Product Material
600D PET
41.5 cm x 6 cm x 31.5 cm
840 g
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Foam padding, adjustable shoulder strap, elastic fixation straps, lockable notebook compartment
Carrying Strap
Trolley strap, carrying handle, detachable shoulder strap
30 years warranty
Product Material
600D PET
41.5 cm
6 cm
31.5 cm
840 g
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Documents, tablet, front pocket
Carrying Strap
REACH
Limited warranty: - 30 years
Brand: Dicota
