The fitall system with integrated grip strap and padded separators fixes your 11 - 15.6" notebook and safety brings it to your destination. The sealable notebook pocket, the high density foam padding and the frame reinforced with metal ensure all-round protection. The padded compartment for an iPad or other tablets (up to 10") protects against impact and is equipped with extra-soft nylex inside. Generous storage space for your documents and mobile accessories. The front pocket with key fob and insert pockets allows you to organize your personal equipment. Long-lasting wearing comfort thanks to comfortable and riveted handles, adjustable, padded shoulder strap and the practical trolley fastening strap. Trolley with high-quality replaceable wheels and integrated telescopic handle.
 - DICOTA Multi Roller PRO Laptop Bag 15.6" - trolley
- Product Type
 - Trolley
- Product Material
 - Polyester, HDF
 - 45 cm x 25 cm x 37 cm
 - 3.5 kg
- Notebook Compatibility
 - 15.6"
 - Adjustable shoulder strap, padded shoulder strap, reinforced frame, elastic strap fastening, slip pocket wheels, lockable
- Carrying Strap
 - Hand grip, shoulder carrying strap, trolley strap
 - 2-year warranty
- Product Type
 - Trolley
- Product Material
 - Polyester, HDF
 - 45 cm
 - 25 cm
 - 37 cm
 - 3.5 kg
 - 15.6"
- Notebook Compatibility Dimensions
 - 38 cm x 26.5 cm x 4 cm
- Additional Compartments
 - Mobile phone, cable, power adapter, documents, pens, clothing, business cards, mobile accessories, Apple iPad
- Carrying Strap
 - Wheels, lockable
 - Limited warranty: - 2 years
