Our actions of today shape the world of tomorrow. That's why DICOTA relies on ecologically sensible solutions and manufactures all ECO collections from sustainable recycled PET. Up to 45 PET bottles are put to second use. You get an environmentally friendly product, with a lifetime warranty. You don't have to do without the well-known quality, feel and look of the rPET products.
Play it safe with Eco Multi PRO! The clamshell bag reliably accompanies you everywhere and meets high standards of quality, functionality and protection. The fitall system with integrated tension strap and padded dividers fixes your 13-15.6" notebook and brings it safely to its destination. All-round protection is provided by the lockable notebook compartment, the padding made of high-density foam (HDF) and the metal-reinforced frame. The padded compartment for tablets up to 12.9" is equipped with extra soft Nylex on the inside. Generous storage space for documents and mobile accessories. In addition, two document compartments on the back. The front pocket with key fob and pockets creates order for personal utensils. Long-lasting wearing comfort thanks to the comfortable and riveted carrying handles, the length-adjustable, padded shoulder strap and the practical trolley fastening strap. This makes the Eco Multi PRO the perfect bag for those who travel a lot and want to support the sensible reuse of PET bottles with an environmentally friendly carrying solution.
- Made from 11 recycled PET bottles
 - Lockable notebook compartment with HDF (High-Density Foam) protective padding and reinforced frame
 - Length-adjustable notebook tension strap with fitall system
 - Padded compartment with Nylex lining for tablets up to 12.9"
 - Front pocket with zipper compartment and pockets for mobile accessories
 - Additional zipper compartment for power supply and cable
 - Two document trays on the back
 - Riveted and comfortable carrying handles
 - Length-adjustable, padded shoulder strap
 - Trolley fastening strap
 - DICOTA Eco Multi Pro - notebook carrying case
- Product Type
 - Notebook carrying case
 - Black
- Product Material
 - Nylex, 600D RPET
 - 42.5 cm x 13 cm x 33 cm
 - 1.16 kg
- Notebook Compatibility
 - 15.6"
- Notebook Supported Sizes
 - 13" - 15.6" / 33 cm - 39.6 cm
 - Reinforced frame, fitall system, padded slip pocket
- Carrying Strap
 - Trolley strap, top carry handle, removable/adjustable shoulder strap
 - 30 years warranty
- Product Type
- Product Material
 - Nylex, 600D RPET
 - 42.5 cm
 - 13 cm
 - 33 cm
 - 1.16 kg
 - 15.6"
- Notebook Compatibility Dimensions
 - 38 cm x 26.5 cm x 4 cm
- Additional Compartments
 - Mobile phone, cable, documents, pens, mobile accessories, chargers, front zippered pocket
- Carrying Strap
- Closure Type
 - Zipper
- Lining Material
 - High-density foam
 - Black
 - Limited warranty: - 30 years
