Dicota Eco Multi Plus 14-15.6"
Quicklinx: GQLBWS00 Mfr#: D30144-RPET
£51.04 ex VAT
£61.24 inc VAT
Our actions of today shape the world of tomorrow. That's why DICOTA relies on ecologically sensible solutions and manufactures all ECO collections from sustainable recycled PET. Up to 45 PET bottles are put to second use. You get an environmentally friendly product, with a lifetime warranty. You don't have to do without the well-known quality, feel and look of the rPET products.
The ideally divided notebook bag Eco Multi PLUS brings your notebook, tablet and mobile accessories safely and comfortably to your destination. The bag reliably accompanies you everywhere and meets high standards of quality, functionality and protection. All-round protection is provided by the lockable notebook compartment, the padding made of high-density foam (HDF) and the metal-reinforced frame. Thanks to a fastening strap and an adjustable partition, notebooks up to 14-15.6" can be reliably fixed. The padded pocket provides reliable protection for tablets up to 12.9". Smartphones, pens, business cards and documents are kept at hand in the holders provided for this purpose in the front pocket. Further storage space for mobile accessories is provided by the workstation inside the pocket and the pocket for documents on the back of the bag. The soft, specially developed handle ensures pleasant wearing comfort. Thanks to the padded shoulder strap and the trolley fastening strap, you always have your hands free - so wearing is fun! This makes the Eco Multi PLUS perfect for those who travel a lot and want to support the sensible reuse of PET bottles with an environmentally friendly carrying solution.
  • Made from 10.5 recycled PET bottles
  • Lockable, padded notebook compartment with High-Density Foam (HDF)
  • Metal wire frame for extra protection
  • Fastening straps and adjustable partition for reliable fixation
  • Pocket for tablets up to 12.9"
  • Front pocket with brackets for mobile accessories
  • Pocket for documents on the back of the pocket
  • Double riveted comfort carrying handle
  • Detachable, padded shoulder strap
  • Trolley fastening strap
DICOTA Eco Multi Plus - notebook carrying case
Notebook carrying case
Product Material
Metal, high-density foam, 600D recycled PET
43 cm x 14 cm x 33 cm
1.17 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Metal frame, elastic fixation straps, padded notebook compartment
Carrying Strap
Trolley strap, top carry handle, removable/adjustable padded shoulder strap
30 years warranty
Product Material
43 cm
14 cm
33 cm
1.17 kg
15.6"
Notebook Compatibility Dimensions
39 cm x 26.5 cm x 4 cm
Additional Compartments
Cable, documents, mobile accessories, front zippered pocket, back hidden pocket, 12.9" tablet
Carrying Strap
Closure Type
Zipper, zipper pocket
Limited warranty: - 30 years
Brand: Dicota
