The compact Eco Multi BASE case offers ideal protection for your laptop thanks to its padded notebook compartment. The case fully protects devices and the elastic strap also secures them within their compartment. The Eco Multi BASE guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
The case's handles make it comfortable to carry and it can be attached to a suitcase in seconds with its built-in strap. It can also be carried using its adjustable shoulder strap. The Eco Multi BASE is therefore perfect for you if you always on the go and want to support the recycling of PET bottles with an eco-friendly case.
- DICOTA Eco Multi BASE - notebook carrying case
- Product Type
- Notebook carrying case
- Red
- Product Material
- 300D RPET polyester
- 45 cm x 6.5 cm x 31 cm
- 660 g
- Notebook Compatibility
- 17.3"
- Notebook Supported Sizes
- 15" - 17.3" / 38.1 cm - 43.9 cm
- Metal frame, elastic fixation straps, padded notebook compartment
- Carrying Strap
- Top carry handle, removable/adjustable shoulder strap
- 30 years warranty
- Product Type
- Product Material
- 45 cm
- 6.5 cm
- 31 cm
- 660 g
- 17.3"
- Notebook Compatibility Dimensions
- 42 cm x 30 cm x 4.5 cm
- Additional Compartments
- Mobile phone, cable, documents, pens, mobile accessories, chargers, front zippered pocket
- Carrying Strap
- Closure Type
- Zipper
- Red
- REACH
- Limited warranty: - 30 years
