Dicota Eco Multi BASE 14-15.6" Grey
Quicklinx: G917WS00 Mfr#: D30918-RPET
£16.36 ex VAT
£19.63 inc VAT
The compact Eco Multi BASE case offers ideal protection for your laptop thanks to its padded notebook compartment. The case fully protects devices and the elastic strap also secures them within their compartment. The Eco Multi BASE guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
The case's handles make it comfortable to carry and it can be attached to a suitcase in seconds with its built-in strap. It can also be carried using its adjustable shoulder strap. The Eco Multi BASE is therefore perfect for you if you always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco Multi BASE - notebook carrying case
Notebook carrying case
Grey
Product Material
Metal, 300D RPET polyester
41.5 cm x 6.5 cm x 29.5 cm
620 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Metal frame, elastic fixation straps, padded notebook compartment
Carrying Strap
Top carry handle, removable/adjustable shoulder strap
30 years warranty
Product Material
41.5 cm
6.5 cm
29.5 cm
620 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, documents, pens, mobile accessories, chargers, front zippered pocket
Carrying Strap
Closure Type
Zipper
Grey
REACH
Limited warranty: - 30 years
Brand: Dicota
