With the ECO Backpack Slim PRO you travel "1st class". The backpack reliably accompanies you wherever you go and meets the highest standards of quality, functionality and protection. Made from high-quality recycled PET, the Slim PRO Backpack protects our planet - ideal for the environmentally conscious consumer. The main material consists of 13 recycled PET bottles. DICOTA's attention to detail makes this bag your most reliable business partner.
The lockable notebook compartment is equipped with memory foam and automatically adjusts to laptops in sizes from 12 to14.1 inches thanks to the fit-all system. Optimal hold is provided by the anti-slip technology coating, which prevents the device from slipping out of the backpack. Best protection for tablets up to 12.9 inches. The front pocket with key ring and pockets keeps your personal items tidy and has room for additional mobile accessories. Maximum carrying comfort thanks to ergonomic back padding, length-adjustable shoulder straps, comfortably shaped carrying handle and trolley fastening strap. Hidden zipped pocket on the back to safely store passport, wallet or other valuables. Side pockets for storing an umbrella or water bottle. The bottom of the bag is made from waterproof material.
- Slim design
- Lockable and padded Notebook compartment with new fit-all system and non-slip technology
- Maximum security thanks to memory foam
- Padded slide-in pocket for tablets up to 12.9" (e.g. Apple iPad Pro)
- Spacious front pocket with zipped pocket, key holder and workstation for accessories, plus power supply and cables
- Hidden zipped pocket for passport, wallet etc.
- Expandable side pocket for umbrella or water bottle
- Comfortable carrying handle
- Adjustable shoulder strap
- Ergonomic back padding
- Trolley belt
- Waterproof material at the bottom
- Made from 13 high-quality recycled PET bottles
- DICOTA Eco Backpack Slim PRO - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Black
- Product Material
- Recycled PET, 600D x 900D polyester
- 29.5 cm x 8.5 cm x 40 cm
- 960 g
- Notebook Compatibility
- 14.1"
- Notebook Supported Sizes
- 12" - 14.1" / 30.5 cm - 35.8 cm
- Waterproof bottom, padded back, built-in memory foam, lockable
- Carrying Strap
- Trolley strap, adjustable padded shoulder straps, top carrying handles
- Limited lifetime warranty
- Product Type
- Product Material
- 29.5 cm
- 8.5 cm
- 40 cm
- 960 g
- 14.1"
- Notebook Compatibility Dimensions
- 35 cm x 24.5 cm x 3 cm
- Additional Compartments
- Umbrellas, passport, wallet, tablet, water, internal hidden pocket, rear external zippered pocket, front zippered pocket, 2 x side pocket
- Carrying Strap
- Closure Type
- Zipper
- Capacity
- 10 litres
- Black
- Limited warranty: - lifetime
