The Eco Slim Case MOTION is a light, slim laptop case. Devices between 12 and 13.3" are well protected in the padded notebook compartment. The slip pocket provides reliable protection for tablets up to 11". The case is comfortable to carry thanks to its padded carrying handle and adjustable shoulder strap. The extra compartment on the back is especially handy for easily storing documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always on hand. The bag is made of water-repellent material to protect the contents even on rainy days. The Eco Slim Case MOTION is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
 - DICOTA Slim Eco MOTION - notebook carrying backpack
- Product Type
 - Notebook carrying backpack
 - Black
 - 32.5 cm x 6.5 cm x 42 cm
 - 640 g
- Notebook Compatibility
 - 15.6"
- Notebook Supported Sizes
 - 13" - 15.6" / 33 cm - 39.6 cm
 - Trolley band, water repellent, padded notebook compartment, padded shoulder straps, ergonomic back, slim and lightweight
 - Limited lifetime warranty
- Product Type
 - 32.5 cm
 - 6.5 cm
 - 42 cm
 - 640 g
 - 15.6"
- Notebook Compatibility Dimensions
 - 38.5 cm x 26.5 cm x 3 cm
- Additional Compartments
 - Front pocket, internal pockets
- Lining Material
 - 600D RPET, recycled PET bottles material
- Compartments Quantity
 - 3
 - Black
 - Limited warranty: - 30 years
