Dicota Eco Backpack SELECT 15-17.3"
Quicklinx: FC2YWS00 Mfr#: D31637
£57.47 ex VAT
£68.96 inc VAT
Made from high-quality recycled PET, the SELECT collection cares for our planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Backpack SELECT's main material is made of 10 recycled PET bottles. The backpack offers first-class protection for your device with its lightweight and particularly shock-absorbing EVA frame protection. Many practical functions for daily use.
The lockable notebook compartment provides the perfect protection for your 15.6 - 17.3" device with amble high-density foam (HDF) padding and perforated, lightweight EVA foam corner padding. The elastic fastening strap makes your device even more secure. The roomy main compartment offers plenty of space for papers or anything else you need to carry. Your tablet (up to 10.5") can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, portable charger, pens and other items. An additional front pocket provides space for chargers and cables. The rear trolley fastening strap, a hidden zip compartment for IDs and the intelligent inner cable routing ensure perfect comfort when traveling.
DICOTA Eco Backpack SELECT - notebook carrying backpack
Notebook carrying backpack
Product Material
Recycled PET
34 cm x 20 cm x 48 cm
1.1 kg
Notebook Compatibility
17.3"
Notebook Supported Sizes
15" - 17.3" / 38.1 cm - 43.9 cm
Rain cover, High-Density Foam (HDF), EVA frame protection, padded tablet compartment
Carrying Strap
Hand grip, shoulder carrying straps
Product Material
Recycled PET
34 cm
20 cm
48 cm
1.1 kg
17.3"
Notebook Compatibility Dimensions
42 cm x 29.5 cm x 4 cm
Additional Compartments
Tablet, front pocket, internal hidden pocket, accessory pocket
Carrying Strap
Closure Type
Double zipper
Limited warranty: - lifetime
Brand: Dicota
