Dicota Eco Backpack SELECT 13-15.6"
Quicklinx: GWZ2WS00 Mfr#: D31636-RPET
Hurry, only 3 left in stock!
£61.60 ex VAT
£73.92 inc VAT
Today's actions shape tomorrow's world. Which is why, here at DICOTA, we are dedicated to developing environmentally friendly solutions and therefore make all the items in our ECO collections out of sustainable, recycled PET. We reuse up to 36 PET bottles, so you will receive an environmentally friendly product with a life-long guarantee. Our PET products also have the quality, look and finish that you know and love.
The backpack offers first-class protection for your device with its lightweight and particularly shock-absorbing EVA frame protection. Many practical functions for daily use. 19.5 litre storage space. The lockable notebook compartment provides the perfect protection for your 13-15.6" device with surrounding high-density foam (HDF) padding and perforated, lightweight EVA foam corner padding. The elastic fastening strap makes your device even more secure. The roomy main compartment offers plenty of space for papers or anything else you need to carry. Your tablet up to 12.9" can also be safely stored in the padded slip pocket. The spacious front pocket helps you keep things organised with its functional division into compartments for a smartphone, portable charger, pens and other mobile accessories. An additional front pocket provides space for chargers and cables. The rear trolley fastening strap, a hidden zip compartment for IDs and the intelligent inner cable routing ensure perfect comfort when travelling. The Backpack Eco SELECT is perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
  • Made of 9 recycled PET bottles
  • 19.5 litre storage space
  • Comfortable shoulder straps, adjustable in length
  • Ergonomic back cushioning made of breathable material
  • Lockable notebook compartment
  • High-Density Foam (HDF) and EVA Corner Foam padding
  • Spacious main compartment
  • Padded slip pocket for tablets up to 12.9"
  • Webbing loop to fix your head phones
  • Smart inner cable management for mobile charging of your devices
  • Front compartment with workstation for mobile accessories
  • Additional zip pocket for power supply unit and cable
  • Space-saving side pockets for an umbrella or water bottle
DICOTA Eco SELECT - notebook carrying backpack
Notebook carrying backpack
Product Material
300D PET
32 cm x 20 cm x 46 cm
0.94 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" / 33 cm - 39.6 cm
Water bottle holder, umbrella holder, cord management system, High-Density Foam (HDF), padded back, EVA frame protection, lockable notebook compartment, 12.9" tablet support
Carrying Strap
Top carry handle, adjustable shoulder strap
Product Material
300D PET
32 cm
20 cm
46 cm
0.94 kg
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Tablet, accessory pocket
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
Brand: Dicota
