Dicota ECO Backpack SEEKER 13-15.6 black
Quicklinx: G1Q5WS00 Mfr#: D31813
Lived sustainability with a clear conscience - the products of the Backpack SEEKER is manufactured from recycled PET and is kind to the environment. Consistent recycling helps to conserve resources. At DICOTA, it's the foundation of our innovative solutions. Within the main material of the Backpack, 16 PET bottles are given a new life - without compromising on quality, functionality or design. The bag offers excellent protection for your devices and is comfortable and easy to carry. Designed for daily use. Equipped with practical functions that make your life easier.
The 23.5 litre Backpack SEEKER offers ample storage space for all kinds of accessories. The lockable main compartment contains a fitall system which allows safe transport for laptops of different depths. The elastic side walls of the compartment can be stretched according to the thickness of the laptop and thus offer a reliable hold. The tablet compartment can safely store devices up to 12.9". The spacious front pocket helps you keep things organized with its functional division into compartments for a smartphone, power bank, pens and other items. There is also a separate zipped pocket with an integrated key holder. As well located in the front area of the backpack is a nylex pocket, which is designed for the scratch-free transport of sunglasses. At the back of the bag there is a hidden zipped pocket where passport, wallet or other valuables can be safely stored. Carrying handles designed for comfort, an adjustable padded shoulder strap, and the trolley fastening strap on the back of the bag ensure that it is both flexible to use and comfortable to transport. The reflective materials on the front of the backpack ensure a safe journey in the dark. These guarantee better visibility without attracting attention in daylight.
  • Made from 16 recycled PET bottles
  • Lockable and cushioned notebook compartment with new fitall system
  • Cushioned slip pocket for tablets up to 12.9" (e.g. Apple iPad Pro)
  • Further compartments for documents & mobile gear
  • Pocket with soft nylex material for sun glasses
  • Spacious front pocket with zip-pocket, key holder and workstation for accessories
  • Additional compartment for power supply unit and cable
  • Hidden zip-pocket for passport, wallet, etc.
  • Side pocket including compression straps for umbrella or water bottle
  • Comfortable carry handle with re-enforcement
  • Ergonomic back cushioning and adjustable shoulder straps
  • Practical trolley belt
  • Waterproof material at the bottom
  • Loop to attach an LED bike light
  • Reflective materials for better visibility
DICOTA Eco Backpack SEEKER - notebook carrying backpack
Notebook carrying backpack
Product Material
Recycled PET
35.5 cm x 23 cm x 48.8 cm
1.1 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" /
Waterproof, padded back, 12.9" tablet support
Carrying Strap
Trolley strap, shoulder carrying straps, top carry handle
Product Material
Recycled PET
35.5 cm
23 cm
48.8 cm
1.1 kg
15.6"
13" - 15.6" /
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Keys, tablet, front pocket, side pocket, internal hidden pocket, accessory pocket
Carrying Strap
Closure Type
Double zipper
23.5 litres
Limited warranty: - lifetime
