Dicota Eco Backpack PRO 12-14.1"
Quicklinx: GDVTWS00 Mfr#: D30846-RPET
Travel "1st class" with the Eco Backpack PRO. The backpack reliably accompanies you everywhere and meets the highest standards of quality, functionality and protection. DICOTA's attention to detail makes this bag one of your most reliable business partners. The fit-all system separating wall in the notebook compartment lies protectively across your notebook and fits automatically to sizes from 12 to 14.1". The perforated and thus light EVA foam material in the lockable notebook compartment perfectly protects the edges of your device. The anti-slip technology coating ensures perfect grip for your notebook in the compartment. The front pocket with a key chain and insert pockets allows you to organize your personal equipment and provides space for additional mobile accessories. The Eco Backpack PRO is perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
DICOTA Eco Backpack PRO - notebook carrying backpack
Notebook carrying backpack
Product Material
1680D rPET polyester
30.5 cm x 20 cm x 39 cm
1.34 kg
Notebook Compatibility
14.1"
Notebook Supported Sizes
12" - 14.1" / 30.5 cm - 35.8 cm
Waterproof, Anti-Slip System, slip pocket, fitall system, lockable notebook compartment, expandable main compartment, 12.9" tablet support
Carrying Strap
Trolley strap, adjustable shoulder strap, carrying handle
Product Material
30.5 cm
20 cm
39 cm
1.34 kg
14.1"
Notebook Compatibility Dimensions
34 cm x 24.5 cm x 4 cm
Additional Compartments
Power adapter, keys, front zippered pocket, hidden zippered compartment
Carrying Strap
21 litres
Limited warranty: - lifetime
