The compact Plus BASE backpack offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case fully protects your device and the elastic strap also secures it within its compartment. The spacious main section is divided so that documents and accessories can be stored separately. The front pocket has practical smaller compartments so you can organize smaller items like your smartphone, pens or chargers. You can safely store your passport, wallet or other valuables in the hidden zipped compartment on the back of the case. There is space for your water bottle or umbrella in the easily accessible mesh side pockets.
You can therefore ensure that everything you need is always to hand. The backpack's ergonomic padding makes it comfortable to wear on your back and the shoulder straps can also be adjusted for further comfort. The Eco Backpack Plus BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
- DICOTA Eco Plus BASE - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Black
- Product Material
- 300D RPET polyester
- 31 cm x 19 cm x 45 cm
- 850 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 13" - 15.6" / 33 cm - 39.6 cm
- High-Density Foam (HDF), elastic fixation straps, padded notebook compartment
- Carrying Strap
- Adjustable padded shoulder straps, padded carry handle
- 30 years warranty
- Product Type
- Product Material
- 31 cm
- 19 cm
- 45 cm
- 850 g
- 15.6"
- Additional Compartments
- Mobile phone, cable, passport, documents, pens, wallet, chargers, power bank, 2 x side mesh pockets, front zippered pocket, back zippered pocket
- Carrying Strap
- Closure Type
- Zipper
- Capacity
- 24 litres
- Black
- REACH
- Limited warranty: - 30 years
