Our actions of today shape the world of tomorrow. That's why DICOTA relies on ecologically sensible solutions and manufactures all ECO collections from sustainable recycled PET. Up to 31 PET bottles are put to second use. You get an environmentally friendly product, with a lifetime warranty. You don't have to do without the well-known quality, feel and look of the rPET products.
The Eco Backpack MOTION optimally protects your laptop with the size 13-15.6" thanks to the notebook compartment padded with High-Density Foam (HDF). The tablet pocket provides reliable protection for devices up to 12.9". The spacious main compartment is divided in such a way that documents and accessories can be stowed separately. In addition, there is a mesh pocket in the main compartment in which the water bottle can be stowed away. The front pocket with practical pockets creates order in your mobile accessories such as smartphones, pens or chargers. The extra zipper on the side of the backpack provides quick access to the main compartment. The backpack lies comfortably on the back thanks to the ergonomic padding. To further optimize comfort, the padded shoulder straps can also be adjusted as desired. The bag is made of water-repellent material to protect the contents even on rainy days. This makes the Eco Backpack MOTION the perfect backpack for those who travel a lot and want to support the sensible reuse of PET bottles with an environmentally friendly carrying solution.
- Made from 13.5 recycled PET bottles
- 23 litres of storage space
- Padded notebook compartment with High-Density Foam (HDF)
- Pocket for tablets up to 12.9"
- Spacious main compartment with subdivision for documents and accessories
- Front pocket with storage space for mobile accessories
- Mesh pocket for water bottle on the inside
- Side zipper for quick access
- Ergonomically padded back
- Comfortable, adjustable shoulder straps
- Water-repellent material
- DICOTA Eco Motion - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Black
- Product Material
- Recycled PET polyester
- 32.5 cm x 15 cm x 47.5 cm
- 750 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 13" - 15.6" / 33 cm - 39.6 cm
- High-Density Foam (HDF), padded back, water repellent, padded notebook compartment
- Carrying Strap
- Adjustable padded shoulder straps
- Limited lifetime warranty
- Product Type
- Product Material
- 32.5 cm
- 15 cm
- 47.5 cm
- 750 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3 cm
- Additional Compartments
- Front pocket, internal mesh pocket, internal slip pocket
- Carrying Strap
- Closure Type
- Zipper
- Capacity
- 23 litres
- Black
- Limited warranty: - lifetime
