Dicota Eco Backpack Dual GO 13-15.6"
Quicklinx: GQHHWS00 Mfr#: D31862-RPET
£63.73 ex VAT
£76.47 inc VAT
The Eco Backpack Dual GO offers ideal protection for laptops. The fitall system separating wall in the notebook compartment lies protectively across your notebook and fits automatically to sizes from 13-15.6". The slip pocket provides reliable protection for tablets up to 12.9". Easily convert from a shoulder bag to a backpack with tuck away backpack straps and a removable, padded shoulder strap. The spacious main section is divided so that documents and accessories can be stored separately. For even more storage space, the main compartment can be expanded with the help of a zipper. There is space for your water bottle or umbrella in the mesh pockets inside of the bag. Open expandable compartment for active gear such as sport shoes, helmet, yoga mat, etc. including elastic mesh side pockets and metal hook for fixation. The front pocket has practical compartments so you can organize smaller items like your smartphone, pens or chargers. Hidden zipped compartment for passport, wallet, etc. The bag is made of water-repellent material to protect the contents even on rainy days. Eco Backpack Dual GO is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
DICOTA Backpack GO - notebook carrying backpack
Notebook carrying backpack
Product Material
600D RPET
31 cm x 16 cm x 42.5 cm
1.04 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" / 33 cm - 39.6 cm
Removable shoulder strap, padded interior, water repellent
Carrying Strap
Padded shoulder straps, top carrying handles
30 years warranty
Product Material
600D RPET
31 cm
16 cm
42.5 cm
1.04 kg
15.6"
Notebook Compatibility Dimensions
26.5 cm x 38.5 cm x 3.5 cm
Expandable
Additional Compartments
Documents, front pocket, internal hidden pocket, slip pockets, accessories compartment, 2 x side mesh pocket
Carrying Strap
Closure Type
Zipper
REACH
Limited warranty: - 30 years
Brand: Dicota
