This compact backpack offers ideal protection for laptops thanks to its high-density foam (HDF) padding. Its lightweight design guarantees flexible mobility. The spacious main section is divided so that documents and accessories can be stored separately. The front pocket has practical smaller compartments so you can organize smaller items like your smartphone, pens or chargers. There is space for your water bottle or umbrella in the easily accessible mesh side pockets.
You can therefore ensure that everything you need is always to hand. The backpack's ergonomic padding makes it comfortable to wear on your back and the shoulder straps can also be adjusted for further comfort. The Eco Backpack BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
- DICOTA Eco BASE - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Black
- Product Material
- 300D RPET polyester
- 34 cm x 15 cm x 48 cm
- 880 g
- Notebook Compatibility
- 17.3"
- Notebook Supported Sizes
- 15" - 17.3" / 38.1 cm - 43.9 cm
- High-Density Foam (HDF), padded back, padded notebook compartment
- Carrying Strap
- Top carry handle, adjustable padded shoulder straps
- 30 years warranty
- Product Type
- Product Material
- 34 cm
- 15 cm
- 48 cm
- 880 g
- 17.3"
- Notebook Compatibility Dimensions
- 42 cm x 30 cm x 4.5 cm
- Additional Compartments
- Mobile phone, documents, pens, chargers, front zippered pocket, 2 x side mesh pocket
- Carrying Strap
- Closure Type
- Zipper
- Capacity
- 28 litres
- Black
- REACH
- Limited warranty: - 30 years
