Dicota Eco Backpack BASE 13-14.1"
Quicklinx: G912WS00 Mfr#: D30914-RPET
£24.64 ex VAT
£29.56 inc VAT
This compact backpack offers ideal protection for laptops thanks to its high-density foam (HDF) padding. Its lightweight design guarantees flexible mobility. The spacious main section is divided so that documents and accessories can be stored separately. The front pocket has practical smaller compartments so you can organize smaller items like your smartphone, pens or chargers. There is space for your water bottle or umbrella in the easily accessible mesh side pockets.
You can therefore ensure that everything you need is always to hand. The backpack's ergonomic padding makes it comfortable to wear on your back and the shoulder straps can also be adjusted for further comfort. The Eco Backpack BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly bag.
DICOTA Eco BASE - notebook carrying backpack
Notebook carrying backpack
Product Material
300D RPET polyester
32 cm x 14 cm x 42 cm
750 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
13" - 14.1" / 33 cm - 35.8 cm
High-Density Foam (HDF), padded back, padded notebook compartment
Carrying Strap
Top carry handle, adjustable padded shoulder straps
30 years warranty
Product Material
300D RPET polyester
32 cm
14 cm
42 cm
750 g
14.1"
Notebook Compatibility Dimensions
35 cm x 24.5 cm x 4.5 cm
Additional Compartments
Mobile phone, documents, pens, chargers, front zippered pocket, 2 x side mesh pocket
Carrying Strap
Closure Type
Zipper
20 litres
REACH
Limited warranty: - 30 years
Brand: Dicota
