With the Eco Accessories Pouch MOTION you enjoy carefree travelling, knowing that all your belongings are perfectly organized and always within reach. Whether pens, charging cables or headphones, the sophisticated interior with a pockets for small accessories provides storage space for everything you cannot miss during your journey. The pouch can be carried comfortably on the webbing-loop. The Eco Accessories Pouch MOTION is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
- DICOTA Eco Motion - case for mobile accessories
- Product Type
- Case for mobile accessories
- 23 cm x 8 cm x 9 cm
- 150 g
- Material
- Recycled PET polyester
- Light grey
- 30 years warranty
- 23 cm
- 8 cm
- 9 cm
- 150 g
- Material
- Light grey
Carrying Case
- Case
- Recommended Use
- For mobile accessories
- Closure Type
- Zipper
- Additional Compartments
- Mobile phone, headphones, pens, charging cables, small accessories
- 30 years
