Dicota DICOTA Travel - Mouse - right and left-handed - 5 buttons
Quicklinx: HGVZWS00 Mfr#: D31980
Type: Mouse
16 In Stock
£7.05 ex VAT
£8.46 inc VAT
The Bluetooth Mouse TRAVEL is the perfect companion for your computer or laptop.
Connect seamlessly to a wide range of devices via Bluetooth, eliminating the need for messy cords and maximizing the workspace and productivity. Compact design, made to fit any hand to comfortably work for hours. Precise navigation thanks to three-level mouse sensitivity of 800/1200/1600 dpi. By changing the dpi, you can instantly adjust the pointer speed to suit the type of work you are engaged in. Navigate effortlessly with the perfectly-placed shortcut buttons. Suitable for right- and left-handed. The mouse battery runs on one AA battery (included).
Compact and lightweight design
Connects via Bluetooth with a wide range of devices
Easy to use and quick installation
No additional software needed
800/1200/1600 DPI for precise navigation
5 buttons including two shortcut buttons
Can be used with a laptop, desktop, at home or on the go
Runs on one AA battery (included in delivery)
On/off button.
DICOTA Travel - mouse - Bluetooth - black
Mouse
Wireless - Bluetooth
Orientation
Right and left-handed
6.5 cm x 10.1 cm x 3.35 cm
102 g
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 800/1200/1600 dpi
Scrolling wheel
AA type
Mouse
Orientation
6.5 cm
10.1 cm
3.35 cm
102 g
Product Material
Plastic
Input Device
Wireless
Bluetooth
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
Scrolling wheel
1 AA battery
AA type
Type: Mouse
Brand: Dicota
