Dicota DataCart
Quicklinx: G92HWS00 Mfr#: N25728K-V1
£195.64 ex VAT
£234.76 inc VAT
The stable cabinet and the extra thick cushions in the Notebook compartment offer the best protection for your mobile computing equipment. Documents can easily be placed in their own compartment or in the separate document pocket. With one quick grip the external bag can be removed from the backside of the case. Two side pockets offer further storage space for mobile accessories. Power supplies are stowed in the custom-designed ABS box. All cables are laid inside the case, which makes them almost invisible. And all devices are supplied with electricity via a single cable through a side opening. To work with your Notebook just remove it from the case. The printer is mounted on the front flap.
  • Stylish and Functional Design
    The DICOTA DataCart features a sleek design that complements any professional setting. The koskin material adds elegance and durability, ensuring the case withstands the rigors of travel.
  • Ample Protection for Devices
    This carrying case is designed to fit notebooks up to 16.4 inches, offering excellent protection against scratches and impacts during transportation.
  • Easy to Carry
    Equipped with a trolley strap, the case allows for hands-free transport, making it easy to manage other belongings while on the move.
DICOTA DataCart - notebook / printer carrying case
Notebook / printer carrying case
Product Material
Koskin
Notebook Compatibility
16.4"
Carrying Strap
Trolley strap
Product Material
Koskin
16.4"
Notebook Compatibility Dimensions
39 cm x 33 cm x 5 cm
Carrying Strap
Trolley strap
Limited warranty: - 2 years
Brand: Dicota
