Simplicity. Functionality. Inspired, contemporary design. These are the guiding principles that define the Code collection. The messenger bag of the collection is the perfect choice for anyone wanting to practically transport their notebook without renouncing on style. The bags of the Code collection are made of polyester canvas fabric and have real leather details. Code Messenger is designed to fit Apple Macbooks but also other notebooks will fit.
The padded notebook compartment provides tailored protection for your notebook. This thanks to the adjustable flap that lets you modify the size of the compartment to fit perfectly with your device. In the large main compartment there is a tablet pocked with room for tablets up to 10-inch. There is also ample space for charger and other accessories and a workstation with pockets for mobile phone, pens etc. Under the flap there is also a small zippered pocket where you can put keys or other items that you need to access easily. For when the rain is pouring the messenger is equipped with a rain cover that is stored in a hidden pocket on the back of the bag. Just pull it out and put it over the bag and your belongings are safely protected from moist. The adjustable shoulder strap is padded for more comfort but the padding is removable for those who prefer a more simplistic look.
- DICOTA CODE Messenger Laptop / MacBook Bag 13" - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Polyester, leather
- 37.5 cm x 12 cm x 26.2 cm
- 970 g
- Notebook Compatibility
- 13"
- Zippered, rain cover, adjustable shoulder strap, padded shoulder strap, High-Density Foam (HDF), removable shoulder pad, adjustable flap
- Carrying Strap
- Shoulder carrying strap
- Product Type
- Product Material
- 37.5 cm
- 12 cm
- 26.2 cm
- 970 g
- 13"
- Notebook Compatibility Dimensions
- 32.5 cm x 22.7 cm x 2.4 cm
- Additional Compartments
- Mobile phone, pens, keys, notebook accessories, tablet
- Carrying Strap
- Black
