Dicota Charging Case Trolley 14 Tablets
Quicklinx: GX3GWS00 Mfr#: D31898
Colour: Black
£550.72 ex VAT
£660.86 inc VAT
The charging trolley ensures that the tablets are always ready and charged when they are needed. Safe storage and charging technology that is both energy- and resource-efficient - for use in a wide range of work and school environments. With the trolley you can charge up to 14 tablets at the same time, with just one standard socket.
Ready to charge in just a few seconds; open the trolley, connect the mains cable to the socket, plug the matching USB cable into the devices and you're done. The included USB cables (USB-C/Lightning/Micro-USB) offer maximum flexibility and prevent cable clutter. LED indicators mounted next to the USB ports show the charging status; green: Charging completed, red: Tablet charging. To protect against overheating, the charging case is equipped with a powerful and quiet fan. Maximum device-protection due to the robust and resistant ABS housing with four lockable latches and splash-protection. The sturdy castors and extendable telescopic handle make it easy to transport between different rooms. The foam padding on the inside also protects the tablets from light impacts.
  • Safely charge and store up to 14 tablets
  • Integrated power supply cables: USB-C (14x), lightning (14x) Micro-USB (14x)
  • Versatile areas of application: Schools, businesses and administrative offices
  • LED indicators show the charging status
  • Robust housing with four locking latches for maximum protection (locks not included)
  • Splash-proof and dust-proof to protect the devices from damage
  • Sturdy, smooth-running castors and extendable handle for easy transport
  • Built-in fan to prevent overheating during charging
  • Easy and accessible cable management
  • On/Off switch
  • Surge protection switch
  • Input: 220 V / 50 Hz / 10 A
  • Output: 5 V DC 2.0 A (max.) x 14
  • Performance: 200 W (max.)
DICOTA - rolling case for 14 tablets
Rolling case for 14 tablets
45 cm x 25 cm x 56 cm
11 kg
Material
ABS plastic
45 cm
25 cm
56 cm
11 kg
Material
ABS plastic
Lining Material
Foam padding
Carrying Case
Rolling case
Recommended Use
For 14 tablets
Protection
Splashproof, low-impact protection, dust-proof, overheat protection
Carrying Strap
Top carry handle, side carry handle, trolley handle
Closure Type
4x latches
Telescopic Handle
Wheels Included
Inner Dimensions
26.5 cm x 18.5 cm x 2.5 cm
Cooler fan, 14 USB-C cables, 14 Lighting cables, 14 micro-USB cables
On/off switch, charge level indicators, surge protection switch
2 years
Colour: Black
Brand: Dicota
Price Range Ex VAT: £500 - £750
