The Car Laptop Charger Universal PRO allows you to charge all your mobile devices (Notebook, Ultrabook, Convertibles, Tablets, Smart¬phones, etc.) on the go with one adapter only. Featuring a 12 - 24 V DC plug, the charger is suitable for cars, lorries, motorbikes, mobile homes, motorboats and many other vehicles.
Power USB-C and USB-A output with Qualcomm Quick Charge 3.0 standard-simultaneously usable for most mobile accessories. Fast charging with up to 100W of power including a 1.2 m E-marker USB-C cable. This makes the Universal Car Notebook Charger the perfect companion for fast energy on the road.
- Universal charger for notebooks, tablets, smart phones and other devices
- Mobile charging on the go for cars, lorries, motorbikes, mobile homes, motorboats and more
- USB-C output including a 1.2 m E-marker USB-C power supply cable (5-20 V, up to 5 A)
- USB-A output - simultaneously usable for most mobile accessories (5-12 V, up to 1.5 A)
- Power: 100 W (max.)
- Protection against over current, overvoltage, short-circuit and overheating
- Compact and lightweight design
- DICOTA Universal PRO car power adapter - USB Type A, USB-C - 100 watt
- Product Type
- Car power adapter
- Designed For
- Mobile phone, notebook, tablet
- 7.5 cm x 2.5 cm x 2.8 cm
- 28 g
- White
- Output Connector Type
- Total 2: USB Type A, USB-C - on cable: USB-C
- Voltage Required
- 12 - 24 V
- Voltage Provided
- 5 - 20 V
- Max Electric Current
- 5 A
- Fast Charge Technology
- Qualcomm Quick Charge 3.0
- Power Provided
- 100 watt
- Cables
- USB-C cable - 1.2 m
- 2-year warranty
- Product Type
- Car power adapter
- Designed For
- 7.5 cm
- 2.5 cm
- 2.8 cm
- 28 g
- Enclosure Colour
- White
- Voltage Required
- 12 - 24 V
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Voltage Provided
- 5 - 20 V
- Output connectors
- Total 2: 9 pin USB Type A, 24 pin USB-C
- Power Provided
- 100 watt
- Detachable Cable Connector Type
- USB-C
- 5 A
- Overcurrent protection, over voltage protection, short circuit protection, overheat protection, compact design
- Material
- Plastic
- Cables Included
- Limited warranty - 2 years
