Protect your mobile equipment within the practically partitioned interior. The separate notebook case is kept save within the lockable front compartment which offers direct access for baggage screening. Furthermore the front compartment features slip pockets for passports, travel documents, power supply units and cables. An additional external zip pocket holds office and travel accessories. The generous main compartment with integrated TSA lock provides plenty of space for clothing and toiletries. Make use of the fixation straps and inside pockets to organize your belongings. The Cabin Roller PRO is equipped with a built-in address tag and two handgrips on the long and on the short side which help to pull the case out of overhead compartments. All you need to travel without worries to every destination.
- DICOTA Cabin Roller PRO - spinner
- Product Type
- Spinner
- Screen Size Compatibility
- 15.6"
- 40 cm x 23 cm x 55 cm
- 3.9 kg
- Luggage Volume
- 49 litres
- Material
- Aluminium, polyester
- Limited lifetime warranty
- 40 cm
- 23 cm
- 55 cm
- 3.9 kg
- Material
Carrying Case
- Spinner
- 15.6"
- Protection
- Stain-resistant, water repellent
- Carrying Strap
- Trolley strap, top carry handle, side carry handle
- Closure Type
- Zipper, pin code lock
- Additional Compartments
- Cable, power adapter, passport, personal accessories, shoes, clothing, tickets, toiletry, address, tablet, internal slip pockets, 2 x front external zippered pockets
- Luggage Volume
- 49 litres
- Telescopic Handle
- Wheels Included
- Inner Dimensions
- 26.5 cm x 3.5 cm x 38.5 cm
- Included Accessories
- Notebook case
- IATA DGR
- Lifetime
