Dicota BASE XX Laptop Slim Case 14-15.6" - Black
Quicklinx: G8XRWS00 Mfr#: D31801
Your notebook will arrive at its destination safely with the BASE XX slim case. The main compartment is furnished with particularly thick padding, which means your device is completely protected from bumps and shocks. Documents and mobile accessories, such as your smartphone, business cards, pens and so on, are always within easy reach in the zip pocket on the front. The length-adjustable and removable shoulder strap and handle make the bag very easy to carry.
DICOTA BASE XX Slim - notebook carrying case
Notebook carrying case
Product Material
300D polyester
40 cm x 4 cm x 28 cm
350 g
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Shockproof, padded notebook compartment
Carrying Strap
Top carry handle, removable shoulder strap
5-year warranty
Product Material
300D polyester
40 cm
4 cm
28 cm
350 g
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3 cm
Additional Compartments
Mobile phone, documents, pens, business cards, mobile accessories
Carrying Strap
Closure Type
Zipper
REACH, PVC-free
Limited warranty: - 5 years
