Dicota BASE XX Laptop Sleeve Plus 13-13.3" Black
Quicklinx: G0HXWS00 Mfr#: D31789
£10.55 ex VAT
£12.66 inc VAT
Professional notebook case with refined functionality. The Sleeve Plus is made of robust PU foam which perfectly adapts to the form of the notebook like a second skin. The best guaranty against surface scratches and other dents and damages. The sleeve is equipped with two zippers. This allows you to charge the notebook or Ultrabook conveniently, without sacrificing maximum protection. On the front there is a flexible pocket with room for mobile accessories. The carrying handles ensure comfortable transportation, but can also be stored in a larger bag to save space.
  • Durable design
    Crafted from jersey and polyurethane, this notebook carrying case is designed to withstand daily wear and tear while keeping your device secure. Its scratch-resistant feature ensures that both the case and the device inside remain in pristine condition, no matter where you take it.
  • Convenient compartments
    Equipped with additional compartments for mobile accessories, this carrying case offers ample space to store your essential items alongside your notebook. This organization aids in keeping everything you need for your day-to-day activities or business travels in one place.
  • Easy to carry
    Featuring a comfortable carrying handle and a double zipper closure, this notebook carrying case is designed for ease of use. Whether you're commuting to work, heading to a meeting, or traveling, the carrying handle and secure closure make it simple to take your notebook wherever you go.
DICOTA BASE XX Plus - notebook carrying case
Notebook carrying case
Product Material
Polyurethane, jersey
35 cm x 2.5 cm x 24.5 cm
180 g
Notebook Compatibility
13.3"
Notebook Supported Sizes
13" - 13.3" / 33 cm - 33.8 cm
Scratch-proof
Carrying Strap
Carrying handle
5-year warranty
Product Material
35 cm
2.5 cm
24.5 cm
180 g
13.3"
Notebook Compatibility Dimensions
33 cm x 23 cm x 3 cm
Additional Compartments
Mobile accessories
Scratch-proof
Carrying Strap
Carrying handle
Closure Type
Double zipper
REACH, PVC-free
Extended warranty: - 5 years
Brand: Dicota
